跳转到主内容
加入维修社区 - 创建账户
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
showing 0146 error
hi
in my system also showing 0146 error but there is no any operating system install in previouslly
when i am trying to boot it will show
Winows failed to start . A recent harxware or software changes might be the cause .to fix the problem:
1) Insert your windows installation disc and restart your computer.
2) choose your language settings and then click next
3) click repaire your computer.
If you o not have this disc , contact your system administrator or computer manufacturer for assitance
status:0x000000f
Info :the boot seletion faild becouse device is inaccessiblle.
if there any solution for above error then plz post that ....
and i also change SATA setting SATA Mode under drive options to ATA from AHCI and save settings. but not working .....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
ganesh, you obviously already tried all the common steps. This error code most often correspond with a failed hard drive. To repair it you will have to replace your drive. Hope this helps, good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ganesh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 113
