跳转到主内容
The dv5-1125nr is an multimedia entertainment laptop that features a 15.4" display, a built in camera, and toggle touchpad
Why won't my display turn on?
I can boot my laptop on and I can hear the sounds from Windows, but the screen is black and it doesn't look like the backlight is on. Is something disabling the screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Nick Loey, the very first thing you want to try is to hook it up to an external monitor and see if that display is working right. If it is you know that your GPU is okay. Then check the LVDS cable and make sure everything is properly seated. If it is, you may need to consider a new LCD since you may have a bad backlight. See if you can see some outlines of your desktop by using a flashlight and angle it toward the screen. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
hi my name is yn .... i like your site .. can you plese heal me...
my laptop not start up destop during booting..
i format twice install new os .... but still this problem ...
this problem gose when i replace new screen ...
my HDD is run in other laptop but not mine one...
but my boot with other HDD... so can you inform me...
完成的
添加一条评论
Puede ser que la lampara de la pantalla esta dañada o floja ya que este equipo utiliza pantalla lcd ; te recomiendo probar conectando un monitor externo para verificar que el monitor tenga en pantalla el sistema operativo completamente cargado.
Saludos
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nick Loey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 1,064
