跳转到主内容
加入维修社区 - 创建账户
惠普于 2013 年 4 月推出的 7 英寸平板电脑,相较于初代产品进行了一些升级。该设备的维修与其他 Android 平板电脑类似,仅需螺丝刀和撬棒即可。有 8 GB 或 16 GB 两种存储容量,以及红色和银色两种配色可选。
How can I replace my HP Slate speakers?
I damage the speakers in my HP Slate and tried replacing them on my own but got stuck. I've gotten to the point in the disassembly where both speakers are unscrewed from the inside and are next to the charging port, but I can't seem to take them out. Am I missing something or are the speakers just stuck to the body of the tablet? I want to be careful not to break the charging port when I take them out. Or do I have to remove the charging port first? And if so, how?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
To ensure there is no damage caused to the motherboard, remove that before any further action. Once that is done, lift up the charging port to remove the left speaker (looking at the tablet from the back).
In order to remove the right-side speaker, remove the volume rocker, carefully lift up the surrounding metal back off the device, lift the silver tape from the charging port to remove the second screw, and then remove the charging port. This will give you access to the second speaker. If you have any confusion about this process, the images in the HP Slate 7 speaker repair guide can assist you further.
这个答案有帮助吗?
得分 3
添加一条评论
Just make sure you lift the battery out and the charge port assembly. The speakers will lift out easily while you are doing this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Davis Muxlow 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 430
