跳转到主内容
A tablet PC in the TravelMate series by Acer, the display rotates to allow for laptop and clipboard-style tablet options, and responds to a stylus.
1 个问题 查看全部
used recovery disks now have no operating system
I have a travelmate c100 that was given to me by my uncle. i tried to start with clean slate so i would have it the way it was unboxed from the factory with the recovery disks. after the first disk finished i inserted the second disk and that cleared out everything including the operating system. i can not get it to read anything and after the flash screen all that comes up is missing operating system.
could someone help me either with a new xp that i can install with the serial numbers on the machine, or at least tell me how to get the recovery disks to start reading again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
chris, it seems that the Recovery Disk does not actually store the image for your system on itself, but rather accesses a partition on the original HD that contains the image. you may either have deleted or the partition is not available, so the CD cannot access it to restore an image. If you can get your system BIOS set to boot from CD and use a Linux LIVE CD to check the partitions on your computer, see what you find. You can of course use programs like FDisk etc as well. Also, you may want to try this place and create your own startup disk. As for a new OS, you might be better served to go out and buy a copy of Windows. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 296
