跳转到主内容
The N95 8GB is a revision of the N95, with a larger screen, 8GB of internal flash storage and larger capacity battery.
2 个问题 查看全部
black screen of death for a Nokia N95 8GB?
I fully charged my nokia - all buttons light up and keys beep and are responsive BUT the screen is black and appears dead. I have a dead screen.
I have googled this issue and a number of others have had the same issue in the past but I cannot find a fix?
Does anyone in cyberspace have a practical DIY fix please? thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Rick Cowan, the only solution I have come across on multiple forums is by placing a jumper across the capacitor C4410. Of course you have to make certain that your LCD assembly is working properly. The service manual further more suggest to check L1150 R1151, C1156 and C1155 visually. make sure that those parts do not look charred or are missing. Let us know how good your skills are with microsoldering and measuring SMC's. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
I also have this problem. I opened the phone up and the problem seems to be the connector from the display that breaks from sliding the screen and time. I think you should buy a new screen asambly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rick Cowan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 15
总计 2,492
