跳转到主内容
加入维修社区 - 创建账户
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
Why is a part missing?
I sent my Motorola razr xt910 to a store of Motorola in my town and when I got back my phone he was cut and a piece was missing I don't know what piece is missing and would be glad if you help me.
Thank you very much,
Netanel Feinstein
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Just out of curiosity, why would they have done that? What was wrong with your phone that you took it to get repaired? any chance you can take another picture of the area where the EMI shield is cut. I wonder if it is only the shield....
完成的
The phone had problem with charging so I took him there and when I got it back I charge and he did not respond at all and so I took out the battery and this is what I saw.
完成的
添加一条评论
1个答案
最有帮助的答案
Okay, so to narrow it down, you will have to post another image with a close up of the area with the cut EMI shield. There are a whole bunch of components under there, mainly the Infineon 5726 SLU A1 H1118 3A126586. I posted an image of what it is supposed to look like. Check the green rectangle area.
这个答案有帮助吗?
得分 2
8条评论:
I think that's the part you marked in green is missing
完成的
By the way thank you very much..
完成的
That is very odd. There are no solder pads and no traces for any of the components. Looks like your logic board is a bit different. What country are you in? Looking at your image it appears as if there are no parts missing at all. If there were parts before, you would see the solder pads. What does your phone do right now? Does it still work?
完成的
If you can see I just opened the shiled (It was easy) and it seems that is more parts that missing
完成的
I'm from Israel the phone aren't responding to anything.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Netanel Feinstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 289
