Why is there no sound?
The volume is up fully and will not produce any noise! Help!
You might have a bad speaker or audio jack. In the case of the speaker you would need to check the connection between the speaker and motherboard. If it was due to the audio jack, cleaning it with an air duster may help. Check out the Troubleshooting page if you any issues.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 27
总计 6,161
4条评论
What is the exact model of phone you have? That way I will be able to further help you know what the exact problem is with your phone.
由 computeripodrepair 完成的
@computeripodrepair, LeapFrog LeapPad2 Explorer is a childrens learning tablet, not a phone!
由 oldturkey03 完成的
Andrew Gough, what have you tried so far? how long has this been going on? Has anything happened just prior to it failing?
由 oldturkey03 完成的
My daughter own is the same problem no sound
由 asheena lawson 完成的
