跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z 是一款 2013 年发布的安卓手机。它是 Xperia 系列中最大的手机之一,配备了 5 英寸全高清显示屏。型号包括 C6603/C6602。
How do I keep I waterproof
How do i replace the full housing with all side flaps and chassis while keeping it waterproof
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
thank you.i already have the original full housing.that was really helpful,i understand that the trick for waterproofing is in the adhesive tape.
完成的
添加一条评论
1个答案
已选择的解决方案
First, buy the original full housing replacement with adhesive sticker.
Then, prepare the back cover adhesive sticker you need, must be original and waterproof.
Next, remove and install the small parts inside carefully and correctly especially pay attention to the headphone jack. If you remove it and you'd better use the glue to fix it when put it back.
At last, press the adhesive stickers between every two parts with much efforts to ensure they are stuck very well.
Sony Xperia Z is not easy to take apart, so be careful enough. Good luck to you!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
zein hamza 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 4,574
