跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Why my iPhone 4 is not booting after touch ic soldering?
This iphone had a problem with the touch screen.
The problem came from the motherboard, because with another screen, it still didn't work.
Since I already repaired an iphone 4s with a faulty touch ic, I thought changing the touch ic on this iphone 4 would fix it.
Problem is, I apparently overheated the motherboard and it does not start.
Here are 2 pictures of the overheated area.
Is there anything I can do to know what is damaged ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Pegston39, the images are not quite as clear, but it sure looks like you got plenty of heat and melted plenty of stuff. Looks to me like you are in for a new logic board. To evaluate all the damage, I suggest you remove all the EMI shields, wash your board with isopropyl alcohol and a soft brush. After that, add a few more high res images of your board to your original question.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Pegston39 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 3
总计 122
