跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
Replacing the motherboard with 8GB RAM, can I?
Hi,
My motherboard is gone due to a spill (advice: if you spill something in the macbook, just bring it in a repair shop for cleanup, as mine lasted 6 more month but would have been OK if I had cleaned it properly).
Anyway, since I am replacing logic board and top cover anyway, I thought I might put in 2.0Ghz i7 with 8GB of RAM instead of the original 1.86Ghz and 4GB.
Are there any incompatibilities between the logic boards of the same year if I put higher end internals? Given that the logic board that I replace with is from a MacBook Air 2012 A1466 same as mine..
Any thoughts? :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
sviests, for as long as you stay in the same year/group you should be okay with a swap. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
sviests 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 14
总计 1,972
