跳转到主内容
加入维修社区 - 创建账户
Google 推出的第一代网络流媒体设备。于 2013 年 7 月发布,型号为 H2G2-42。
Red light no matter what?
Hi, I have a google chromecast and when I set it up everything worked perfectly. I unplugged it for the night and then I plugged it back in and it had a red light. I tried factory resetting it but the light still stayed red and the reset button is not stuck. Anything that I can do?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
Try swapping out the USB cable that comes with it, apparently several people were given a cheap faulty USB cable that would stop working after a day or two. Many have found salvation by using a known good USB cable. Let me know if this doesn't work. Oh as far as the reset button you should feel a definite click, if you don't press the button repeatedly to loosen it up.
这个答案有帮助吗?
得分 4
2条评论:
Changing the usb cable worked for me. thanks so much!! such a simple solution but had me stumped. thanks again.
由完成的
I have an original 2013 Chromecast and it just stopped working now - July 2022! I know this is an old post, but just commenting as I came across this, and tried changing the cable as a last attempt before throwing it away and it worked!
由完成的
添加一条评论
Hi
Mine did the same. My Ccast remained plugged in and working great for a few months. Then one day, I noticed the LED was off.
I have tried many power supplies and cables. No luck. Even with a USB inline volt and ammeter plumbed into the supply. It shows no current draw from the C-cast.
Anyone else have this. ??
这个答案有帮助吗?
得分 1
添加一条评论
i am using the chromecast 2 audio only mode with 4k hdmi converter, red light always blinking bt it extracted audio perfectly.
这个答案有帮助吗?
得分 0
添加一条评论
When I turn on the chrome cast the white light is blinking. But it is not showing in my device
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ted Mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 41
总计 27,314
