Can I repair the screen?
Is there a way to repair a broken screen?
All the rest works well, it's just the screen, especially the bottom-right corner where some little black pieces are missing.
Thank you!
Stefania Delprete, even so it is not a guide, the teardown from here will show you how to get to the display panel. Also take a look at this videoas well as this one. The assembly is available at places like this as well as on here. Hope this helps, good luck.
这个答案有帮助吗?
Thank you, oldturkey03!
Your screen is broken and you need to replace a new one.
这个答案有帮助吗?
Thank you, I knew that. How can I do that?
Do you you know where can I buy the new screen and how can I remove the broken one and replace it with the new one?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 643
