Can I add a bluetooth card to this machine
there is a bluetooth port but no card blue tooth ant sign above F1 but no function switch icon at f2 or anyware else can I still upgrade this machine?
robert, enter the service tag from your computer on this site. It should provide you with a list of components and options for your individual computer. Hope this helps, good luck.
这个答案有帮助吗?
Isn't a bluetooth already there in Dell's build up. I have a Vostro and bluetooth is built-in inside. Latitude is an old model, I suppose, you have to look into Dell Store for sure or I think a local technician may also help you out.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 454
3条评论
the laptop didnot have blue tooth when i got it i did inspection of it and it has the port just want to know if i can upgrade it
由 robert 完成的
Do you have the slot labeled WPAN/UWB/FCM on your motherboard?
由 oldturkey03 完成的
yes port has small blue wire at it
由 robert 完成的
