跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
797 个问题 查看全部
How to get into "service" mode.
Sometimes my unit will not work correctly and would like to know how to get into the diagnostic mode to make sure everything is alright and what may be causing it to: locking still allows pressing button to function unit; volume to fade in display at various times. Thanks in advance. Mike
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Mike, here is a great link to how to enter diagnostic mode. It will even tell you what the results mean. Hope this helps, good luck
这个答案有帮助吗?
得分 1
2条评论:
No link showed up.
完成的
Mike, try again. Just fixed the link and it should work.
完成的
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 222
