跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
How to get USB 2.0 on this model?
Please inform whether it is possible to get USB 2.0 via extension card, and if so, where to get one.
There are people claiming that hard-wiring inside the machine effectively will prevent any buscard solution. Also, there seems to be restrictions on buscard types working on this model.
I'll be ever so grateful for tips, as info so far seems both contradictory and confusing.
Newcomer
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
I've never tried one of these, but you can get a Firewire to USB2 converter:
http://cgi.ebay.com/Male-Male-USB-2-0-Fi...
这个答案有帮助吗?
得分 4
4条评论:
Agreed +
完成的
yeah good workaround
完成的
完成的
This is a male to male.. just pointing that out
完成的
添加一条评论
Yeah, you're logic board won't be able to handle USB 2.0, so it's a no go.
这个答案有帮助吗?
得分 0
添加一条评论
I'm pretty sure theres a PCMCIA port on your PowerBook. Try this:
USB 2.0 PCMCIA Cards
这个答案有帮助吗?
得分 0
3条评论:
This is a PowerBook, not a MacBook, all MacBooks have usb 2.0
完成的
I meant PowerBooks. I think none of the MacBooks have PCMCIA card ports
完成的
You should update your answer to say PowerBook instead of MacBook then... ;)
完成的
添加一条评论
添加你的答案
BELarsen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 774
