跳转到主内容
20", 23", 和 30" LCD 显示器 发售于2004 于 2010年停产。
How to disassemble a 23" Apple Cinema Display (A1082)?
My display is intermittently not lighting usually after waking from deep sleep and seems to be getting worse. I've isolated it to the monitor not the video card. Apple wants ~$800 to repair it but I can find displays on eBay for $100-300, some with destroyed cases. If I purchase one of these how do I install it in my current housing? There are no obvious ways into the aluminum case (no screws I can see). I'm an engineer and have no qualms about opening it but I'd like some direction on how not to damage the case when opening it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
7个答案
已选择的解决方案
i've posted 2 links in this posting<- this is a link ;-)
这个答案有帮助吗?
得分 4
1条评论:
Nice reference + Ralph
完成的
添加一条评论
最有帮助的答案
Essentially as follows:- (for the 23") ( 20" and 30" are similar in principle):-
1) plenty of workspace / soft towel or similar on bench
2) Remove the two large-ish round finisher screws on either end of the hinge (hex key)
3) Remove the 4 small fixing screws under the hinge ( Torx) and ease the foot/hinge assembly off the screen. Springs etc all stay in place and the foot is easy to put back on afterwards.
4) Carefully ease off the two plastic side cheeks ( thin craft blades or similar ) starting at top or bottom edge. CARE - they are held by thick super-grip pads & will break if forced. NOTE the small cable to the power button on RHS. Warming with hair drier can help.
5) take the 4 screws out of the long metal plates now exposed on each side and lift the plates through 90' to disengage the hooks. NOTE how they went on and put to one side.
6) Locate the two small metal tags now exposed at the lower edge on each side - pull outwards about 5mm in order to disengage the catch assembly along the lower edge.
7) held upside down (assistant useful) the bottom edge can now be held open about 5" or 6" ( NOTE the small cable to the power LED as you open the case), and the LCD assembly can be carefully removed taking great care NOT to scratch the panel on the now exposed and sharp metal lugs. Ease the heavy cable through its hole as you go.
8) The main components visible are the wiring harness, the Inverter board (LHS) and the Power / signal board on the RHS. Be careful if replacing the power board as there was more than one variant of this (the upper right signal cable / socket can have 15 OR 16 pins).
9) Spares are not easy to find, were not listed by Apple and so almost always come from cannibalised broken screens - so be sure of the source you buy from.
10) Re-assembly is of course a systematic and careful reversal of the above.
FOOTNOTE: (Jan 2017)
This is an old post now and many of these screens have gone..... however.......
A good many of these displays suffer from a flashing power light when turned on and it appears that this can derive from a problematic signal on a ground sensing pin from the main board via the power lead to the power brick.....
In about 50% of cases I have successfully 'resurrected' displays by isolating this pin signal......... as follows......
a) Examine the power plug ( i.e. the one that plugs into the power brick) - its pins are duplicated on both sides so that it can be plugged in either way around. The centre pin ( on both sides) is where this 'ground sensing' happens.....
b) To isolate it, ( this is a bit fiddly - so be patient ! ), cut a small strip of Kapton tape ( the clear yellow stuff), about 25mm long and 3mm wide (1" x 1/8" ) and carefully lay this across the centre of the plug such that its directly above both of the centre pins.....
c) Using a thin tool, gently push the tape into the plug at its centre, i.e. so it forms a loop into the plug, covering the two centre pins ( and no others) with an equal amount on each side sticking up out of the plug. If it doesn't work first time, cut another strip and try again.
d) once fully pushed home, carefully fold the excess tape on each side back over the plug shell and the carefully insert into the power brick. Test the display.
If it works - Great, if not....well it cost nothing to try.
Its also the case that some of these monitors consume more power over time and can get to a point where they are demanding more than the power brick can supply - resulting in the power brick clicking on and off ( safety cut-out ).
Equally, an old / tired PSU can sometimes reach the point where it can't deliver what it was designed to do and again, may start cutting-out as the display draws power.
The 20" used a 65w psu, the 23" used a 90w psu and the 30" a 150w supply, the smaller PSUs were not exactly 'over spec'd ' by Apple.
For the smaller screens, using the psu from a bigger screen sometimes works where the original psu will not....... If however, you suspect that the screen has power issues ( burning smells / frayed or charred leads/ etc etc), then use common sense people and DON'T give it more power to cook itself with !!
A late-in-the-day post I know, but there are still plenty of people out there using these ageing displays, so maybe these 'tips' will help someone keep their Cinema display going a bit longer, but please be sensible people, I accept no responsibility for you cooking or frying a monitor that's in bad or unsafe condition.
这个答案有帮助吗?
得分 15
7条评论:
Perfect: Thank you!
完成的
Hi there, thanks for your guides...
Just wondering how the ground signal goes to earth if you isolate the ground pins ?
PS : I need the answers but it works for me :) Thanks man
完成的
While the schematic circuitry for these monitors doesn't appear to be in circulation (I've never found any), it would seem that the centre pin is not the monitor's grounding point but is a ground 'sensing' pin...... i.e. seems to act as a 0v reference point. WHY isolating this sometimes works is not clear (to me), but that fact that it often does.....is useful !
完成的
I've been lugging one of these screens around for years... I knew someone would eventually share how to repair the problem with flashing power light!! Thank you!
完成的
if you take and cut the insulation closest to the power in on the monitor and cut away the metal shield material until you have the 2 wires showing that will fix the problem. just tape it together, you want the metal shielding completely stripped away where you only have 2 wires left showing.
完成的
显示更多的2条评论
添加一条评论
Hi im at the same place your at. But i did attempt to doit it myself. I have a apple 23" cinema display. The right side has the power and brightness touch buttons. If you have the same Then these side panels are held by double sided sticky tape. be careful though as there is a wire you can snap.
From this point you can start to feel your way to breakdown the monitor.
Hope this helps.
Update
http://s807.beta.photobucket.com/user/bu...
这个答案有帮助吗?
得分 3
1条评论:
Darren, that is a great answer. Only problem is that the question is way over 2 years old and has not been commented on since then. I think you should make a guide out of this and post it with the Device on here. That way people looking for help would know where to find it. http://www.ifixit.com/Guide/new/Device/A...
完成的
添加一条评论
I have a Cracked Screen HD Cinema Display and wanted repair by buying new screen and replacing it but I have no idea where to get the LCD screen from. Any suggestions
这个答案有帮助吗?
得分 0
1条评论:
Hi, you may have trouble finding the screen as a part on its own. To the best of my knowledge Apple never listed spares for any of these displays (20" / 23" / 30" ). If yours is a 23" then I believe the part number is: LM230W02STB, but it may be easier / cheaper / simpler just to buy another working 23" Cinema Display to replace it..........FleaBay?
完成的
添加一条评论
23” service manual:
< https://www.manualslib.com/manual/124378... >
这个答案有帮助吗?
得分 0
添加一条评论
Apple cinema display 23", first some times do not open, solution open power supply and i find one "balloon" capacitor, after that change, work perfect again, now, make black screen with sound, and after few seconds open again, i check power suply with multimeter, and I see is not support 24 volt. i try to insulating the middle arc from power usb, and work again, I suppose its power supply is foul, and not the monitor
这个答案有帮助吗?
得分 0
添加一条评论
Cinema HD Display (23-inch DVI) Take Apart
https://www.applerepairmanuals.com/the_m...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Gilbert 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 96
总计 54,952
