跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
Installing second SSD in iMac 27 2013 SSD only model
Hi all,
I would like to add another ssd in my iMac 27 2013 model. my question is, if there are already the needed adapter/bay, cable inside, as in the fusion model?
I would like to add a 500gb or 1tb samsung evo ssd. Is this possible?
Thank you all for your help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Yes, you can do this on an EMC 2639 body iMac ~14,2. I just did it.
As the previous poster explained, you need to follow this guide: iMac 因特尔 27" EMC 2639 硬盘更换
You need these parts:
http://www.powerbookmedic.com/Intel-iMac... (this was very difficult to source)
[关联产品丢失或禁用: IF174-005]
I was unable to source the hard drive cage so I used some really strong 3M double sided tape. Now my iMac has 1.5 TB of flash storage :)
这个答案有帮助吗?
得分 2
添加一条评论
Here's the IFIXIT guide you'll need to follow: iMac Intel 27" EMC 2639 Hard Drive Replacement.
In your case the HD is missing! And yes, the mounting hardware & cable assembly is as well.
The next issue you'll face is needing an adapter frame to hold your new 2.5" SSD to fix into the 3.5" mounts of the expected HD. (unless you get a 3.5" version).
This is not an easy job.
这个答案有帮助吗?
得分 0
2条评论:
Thank you, for taking the time to answer my question. I have become very familiar with disassembly. My problem now is where to find the hardware and cable to add the additional drive, 3.5" HDD or smaller SSD.
完成的
OMG! The question are “ADD A SECOND DRIVE” not REPLACE the drive. in late 2013 14,2 iMac model are NOT POSIBLE add a second drive to have an SSD for OS and the default drive for files. Two drives, the default HDD and a second SSD drive. Not posible.
完成的
添加一条评论
添加你的答案
Uli 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 1,631
