跳转到主内容
加入维修社区 - 创建账户
适用于配备 CDMA 3G 蜂窝网络(Verizon)的第二代 Apple iPad 的维修指南、拆解和故障排除信息,可选 16、32 或 64 GB 存储空间。搭载双核 A5 处理器。于 2011 年 3 月发布。通过型号 A1397 识别。维修需要加热并小心撬开。
ipad 2 not activating error
This is sorta a follow up to a previous question I had asked.(Replaced digitizer and antennas, still searching..)
None of the previous problems were fixed btw.
So we were instructed to restore the ipad to factory. Now we are getting the:
"Your iPad could not be activated because the activation server is temporarily unavailable. Try connecting your iPad to iTUnes to activate it, or try again in a couple of minutes.
If this problem persists, contact Apple Support at apple.com/support"
What do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
Mine to just after updating to 9.3 - totally bricked my iPad2
由完成的 分享
添加一条评论
5个答案
最有帮助的答案
I would check for damage in the flex between the main board and the cell service board
这个答案有帮助吗?
得分 1
1条评论:
Hi Jessa,
Vortex's comment below seems to describe the problem I'm having on an iPad 4 which came to me for a battery replacement, it was re-booting every couple minutes.. New battery - No Change, Log files report temperature sensor failure on sensors 0,6 & 1. iPad wont Activate, displays "searching"
Question : if I can find someone that can replace the base band chip, will it function as normal..
Many Thanks
Paul
由完成的 分享
添加一条评论
look into log files..
I think baseband temperature sensor fails working causing the part to shutdown, causing the device to reset, and so on
see also Nathan Rakes post, which ist the effect caused by this
这个答案有帮助吗?
得分 1
添加一条评论
I have seen this error many times on iphones with broken baseband chip after water damage or impact damages.
Itunes trying to read device's baseband chip (IMEI number or something like that) to activate the phone.
I guess same thing happening to your ipad CDMA. Baseband chip looks like not functioning.
Reasons
1- If its water damaged try to clean mainboard shortcuts and resolder corroded components.
2- if it has impact damaged, using hot air on the baseband chip may bring the baseband function back. I dont know What temperature and howmany minutes. But you can google for it.
Good luck ...
这个答案有帮助吗?
得分 0
添加一条评论
Hi.
How can i check the flex between board and cell service board?
I mean, if i check bouth sides of the flex i have continuty, but how can i check if the pads are soldered well?
Thanks?
这个答案有帮助吗?
得分 0
添加一条评论
What i want to do with my Ipad 2? Activation server is unavailable?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nathan Rakes 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 43
总计 7,332
