跳转到主内容
加入维修社区 - 创建账户
德州仪器于 1996 年发布的一款热门图形计算器。
How to fix the graph
When I plug in a problem like in the y= and then go to graph it my graph is only shoring up on the left side so all you can see is the bottom and top of the y axis which is normal but all you can see on the x axis is the right side. So it won't show the full graph but rather just the left. How do I get it back to a normal graph?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Hi Britney,
It sounds like you need to adjust the window of the graph. You can do that by clicking on the 'window' button and filling in the Xmin, Xmax and Ymin and Ymax values.
Or you can do it the easy way by clicking on the 'zoom' button and then selecting 'ZStandard'. It will change to window of the graph to the standard size of -10 and +10 on both axes.
Good luck!
Nathan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Britney Benard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 598
