跳转到主内容
GE 数码相机的维修指南和支持,由通 General Imaging 生产,并以通用电气品牌名称销售。
when I turn on my camera it says lens obstruction
Ok so when I try turning my camera on it says lens obstruction and the lens wont come out and after awhile it turns off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
9条评论
I had experince too
完成的
My camera brand GE 14.1 megapixel E1450W
完成的
i tried to turn on my kodak pixpro az252 and it says lens obstruction and turns off how do i fix it
完成的
Mine is a BRAND NEW Kodak PIXPRO AZ252 Bridge Camera. I had just opened it the day I bought it and it said lens obstructed Restart camera and then it shut off. I am really mad. The shutter and lens does not even come out.
完成的
Same how do you fix it I have the FZ41
完成的
显示更多的4条评论
添加一条评论
1个答案
已选择的解决方案
Juanita Gonzalez, this is most likely caused by a stuck lens. These errors are more common with an extended lens, but can also appear in a retracted lens. Take a look on here to see how to deal with it. It will be the same for most brands. If this does not work, you may be looking at replacing the lens itself. Since you did not tell us what model your camera is, we can not provide any further details with that. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
11条评论:
my camera is a kodak easyshare c195 14 megapixel with 5x optical zoom.. any tips??
完成的
Mine is a Kodak Pixpro AZ251, and I know I deopped my camera, and after I dropped it It said lens obstruction, restart camera. what do I do now?
完成的
Im having the same problem with my GE X500 Camera..pls need a solution .thank u
完成的
i have the same camera with the same problem
完成的
my camera doesn't work and it always says that lens obstruction. what should i do?
完成的
显示更多的6条评论
添加一条评论
添加你的答案
Juanita Gonzalez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 52
总计 21,445
