Where is the turnsignal flasher on 94 cavalier?
I found the hazard light flasher but not the turn signal flasher
Johnny Hale, the turn signal flasher is located located behind the instrument panel, on the left side of the steering column bracket. Replace the flasher by unplugging the old one and plugging in the new one. (usually;-) Hope this helps, good luck.
这个答案有帮助吗?
Thank you! Your diagram is way better than the one in the Cavalier shop manual.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 1
过去的30天: 10
总计 2,851
