跳转到主内容
加入维修社区 - 创建账户
2013年中期推出的Xbox 360改款机型,提供4个USB接口和内置Wi-Fi功能。
Remove RF module or just RF chip?
Question on RF module in XBox 360 E: to disable RF emission / reception, is it sufficient to remove the RF chip on the module, or should the WHOLE RF module be removed? Is there anything else RF-related on the module apart from the actual chip?
Thanks for any advice.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
I am just a student working on these repair guides, but to the best of my knowledge, that RF module is the only RF related device in the Xbox. That module is the connection to the button board and can't be removed entirely. I also do not know how to remove or disable the RF chip alone. Our Xbox we get to work on is not functional, but maybe there is an option in the software to disable the RF.
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
Thanks for your answer. We were wondering f there might be some other RF-related item lurking in the box, but I guess not. It turns you can remove the module altogether, but then you have to start up the console using a wired controller since the button panel won't work any more.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cameron 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 1,039
