跳转到主内容
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
Dropped phone. Why striped unresponsive screen, yet phone audio and m
I dropped my phone. Now, as I turn on the device, I can hear all the audio activity. But the screen lights up with numerous vertical lines. Some thin, some wide, and some others even wider. Within a few minutes, the screen fades to black. No apps showing, nor am I able to use any of the four icon buttons at the bottom the phone. I can still use the volume, and can hear chimes of when incoming message actvity or other notifications takes place. In fact while its on it even prompts my wake alarm as I had t set before the drop. Can't silence the alarm unless I take the battery off, as there is nothing on screen for me to select. Is there any hope on repairs for this device.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
higonz32, "But the screen lights up with numerous vertical lines" sounds like a broken display. To confirm this, you could post an image of your display with your question. Use these guides to replace the LCD. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
higonz32 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 449
