跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 个问题 查看全部
iMac (Mavericks) stuck on boot (only apple logo)
Dear friends,
last week I found my iMac stuck on screensaver, I couldn't do anything but forcing shut down. After restart I noticed that the boot process stuck on apple logo, the sequence is as follow:
1- I press the start up button
2- I can hear the chime and white screen with apple logo
3- Also spinning gear comes out
4- Then spinning gear go off and iMac remains stuck on white screen with apple logo
I performed the following actions:
- I reset PRAM and NVRAM
- I boot from CD or recovery partition and performed a User Permission Repair, a disk Verify, an OS installation over the previous OS and a total formatting of the internal disk with a new OS installation.
Nothing changed. I can only access in safe boot mode. Could be maybe a video card issue?
Strange thing: after resetting the PRAM (that brings the mac screen at the max brightness) when spinning gear comes off the system lowers down the brightness as if it should enter the OS but remains stuck. Maybe the video card is not the issue?
Thanks for help,
Paolo
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
How long do you let it search (boot)? At least 10 minutes. If it were a GPU issue I don't think you could boot to repair partition… I think you may have a failing HD. Run AHT and see what it says.
完成的
I already performed an AHT but no issue has been found.
I'll try to install a new system in an external unit.
完成的
Some issues only turn up in AHT under stress… run it in advanced mode 2 or 3x in a row.
完成的
Please give us the last four figures of your serial number or tell us if it is one of these: (for example, xxxxxxxxDHJQ):
DHJQ, DHJW, DL8Q, DNGH, DNJ9, or DMW8
DPM1, DPM2, DPNV, DNY0, DRVP, DY6F, F610
完成的
Any further info/updates on this issue? I am experiencing same problem.
完成的
显示更多的2条评论
添加一条评论
5个答案
最有帮助的答案
Had the same problem, Macbook air/Mavericks hanging on startup with apple logo and spinning gear. Tried many solutions including the ones on this page, no luck.
Finally:
Boot to recovery: With computer off, press & release power button then immediately press and hold Command + "r" until recovery screen appears.
Open terminal: In the recovery screen, on the top menu bar click "Utilities" then "Terminal".
Type each of the following commands in terminal:
"mount -uw /"
press enter
"chown root /"
press enter
"chmod 1775 /"
press enter
"exit"
press enter
Close terminal and click restart from the top menu bar.
I must admit that I caused this problem myself by changing the permissions on my startup HD.
Hopefully this helps.
这个答案有帮助吗?
得分 3
2条评论:
How did you determine this fix and what exactly does it do? I am having the same issue with my imac (EMC 2374 Late 2009, Core i5 2.66 GHz) and have tried everything but fixes in terminal. I can target my drive from another mac and have it boot no problem...seriously nonplussed.
完成的
OMG that worked for me!!!
完成的
添加一条评论
This is 100% a failing hard drive just hasn't failed completely yet. It could also be a bad SATA Cable.
If you open disk utilities in the boot CD, click on the hard drive (not the partition name) and at the bottom it will say S.M.A.R.T.... Verified means everything is good but sometimes it will say Failing.
It's most certainly a hard drive issue.
Update
This is tricky! It could still be but it could also be a GPU problem.
If you have an external hard drive, try installing OS X on to that the same way you do to the internal hard drive and just boot to that by holding down the Option key on boot.
If it loads fine from the external it's a HDD problem, if symptoms persist then probably GPU.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for answer. Yesterday I downgraded the system to OSX lion and this is what I get after boot: http://imgur.com/PBOICfR
Is still an hard drive issue?
完成的
Here we are: S5RU
完成的
添加一条评论
graphix=yes -x Before You boot from Maverick Partition
这个答案有帮助吗?
得分 0
添加一条评论
This is NOT necessarily a hard drive problem. I have a 3 TB hard drive with two partitions. I have been using Mavericks one the #1 partition for a month, I'm on it now. I downloaded 10.9.4 yesterday and installed it onto the #2 partition. I then used Migration Assistant to move my user data and settings. When trying to boot from the new system I can only get to the Apple in both full start up mode and in Safe Mode. I let it try to start up all night with no results except to reboot onto the original partition. Sorry I don't have an answer but obviously it's not my hard drive failing or a GPU issue as my Mac Pro is running just right now.
这个答案有帮助吗?
得分 0
添加一条评论
I also had the same issue.. The Apple guys have replaced the hard disk..but after a day the same issue happened again..Now I am waiting for the Apple person to fix it permanently.. In India the apple service is $@$*!&..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paolo Pizzuti 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 33,887
