iMac (Mavericks) stuck on boot (only apple logo)
Dear friends,
last week I found my iMac stuck on screensaver, I couldn't do anything but forcing shut down. After restart I noticed that the boot process stuck on apple logo, the sequence is as follow:
1- I press the start up button
2- I can hear the chime and white screen with apple logo
3- Also spinning gear comes out
4- Then spinning gear go off and iMac remains stuck on white screen with apple logo
I performed the following actions:
- I reset PRAM and NVRAM
- I boot from CD or recovery partition and performed a User Permission Repair, a disk Verify, an OS installation over the previous OS and a total formatting of the internal disk with a new OS installation.
Nothing changed. I can only access in safe boot mode. Could be maybe a video card issue?
Strange thing: after resetting the PRAM (that brings the mac screen at the max brightness) when spinning gear comes off the system lowers down the brightness as if it should enter the OS but remains stuck. Maybe the video card is not the issue?
Thanks for help,
Paolo
7条评论
How long do you let it search (boot)? At least 10 minutes. If it were a GPU issue I don't think you could boot to repair partition… I think you may have a failing HD. Run AHT and see what it says.
由 originalmachead 完成的
I already performed an AHT but no issue has been found.
I'll try to install a new system in an external unit.
由 Paolo Pizzuti 完成的
Some issues only turn up in AHT under stress… run it in advanced mode 2 or 3x in a row.
Please give us the last four figures of your serial number or tell us if it is one of these: (for example, xxxxxxxxDHJQ):
DHJQ, DHJW, DL8Q, DNGH, DNJ9, or DMW8
DPM1, DPM2, DPNV, DNY0, DRVP, DY6F, F610
由 mayer 完成的
Any further info/updates on this issue? I am experiencing same problem.
由 solect 完成的
显示更多的2条评论
