跳转到主内容
加入维修社区 - 创建账户
2.4GHz、2.7GHz 或 2.8GHz 四核 Intel Core i7 处理器(Turbo Boost 最高可达 3.8GHz),配备 6MB 共享三级缓存。2013 年 2 月发布。
MacBook Pro Retina Display Activation?
Is there an activation code for Macbook Pro Retina Display, because I have 2 MBPr and one display were dead (black), in order to be sure that only the display is defect I use the display from the othe laptop to test, but when I put the display back to the second laptop it doesn't work. And I'm wondering if there are activation codes for the MBPr to work with the installed display.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Ouch!
So while there is certainly the possibility that I am wrong (although in this case, I doubt it), it sounds like... you either:
1. shorted the logic board fuse for the backlight of the one you returned it to (where you originally took the screen from)
2. damaged the pins on the cable from the display
3. damaged the port on the logic board for the cable from the display
4. didn't seat the cable properly and need to re-seat it.
As far as the activation, there is none. I know this for a fact. HOWEVER, Apple DOES keep a record of the serial number from the display and which System Serial it's supposed to be tied to. However, they only record it from the macs that come into their stores for work or repair. They do not record the data from the macs off the assembly lines. Just FYI
由完成的
添加一条评论
2个答案
最有帮助的答案
Ouch! So while there is certainly the possibility that I am wrong (although in this case, I doubt it), it sounds like... you either:
4. didn't seat the cable properly and need to re-seat it. As far as the activation, there is none. I know this for a fact.
这个答案有帮助吗?
得分 1
添加一条评论
I have never heard of there being activation codes for Apple hardware installations. I recommend double checking the connections.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 18
总计 1,418
