iPhone will not connect to iTunes
I'm trying to connect my new iPhone to iTunes but it will not install the drivers. I get an error message saying cannot connect iTunes because the device timed out. However my iPhone is up and running.
Mel, make sure that iTunes and the iOS Software is up to date. Then disconnect the phone. Do a hard reset by holding down the sleep/wake button, and home button, until the phone completely turns. Then re-connect the phone back to the computer and see if that resolves the issue. Also, check your dock connector and make sure that it is clean, no broken or bend pins. Try a different cable and/or a different USB port/computer. Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 4,610
