跳转到主内容
加入维修社区 - 创建账户
The Kindle 4 has 4 models released September 28, 2011.
Kindle will not switch on
my kindle was fine when I switched it off, but will not turn on again. I have tried this with the mains connection on & off. When pressing the on/off button, the green light comes on, briefly, then --- nothing!
The charging light seems to work, but the kindle will simply not boot! Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
6条评论
the back won't come off
完成的
got the back off wares battery
完成的
kindle 4 will not let you take it out what do i do how
完成的
the battery is glued down
完成的
I fixed it by disconnecting and reconnecting the battery. I followed this tutorial: Kindle 4 Screen Replacement until step 2, then reattached the battery and reassembled the back.
完成的
显示更多的1条评论
添加一条评论
3个答案
最有帮助的答案
I had the same problem as you.All you need to do is hold in the start button for 20 seconds and it will reboot the kindle and it will reload everything.
这个答案有帮助吗?
得分 1
1条评论:
Worked for me! I think my initial problem was I left the kindle battery to drain for too long. I need to remember to charge it. Thank you!
完成的
添加一条评论
i had the same Problem with a kindl. Disconnect the battery from the logic board, wait for about 2 minutes and connect the battery to the logic board. This helped me...
这个答案有帮助吗?
得分 0
2条评论:
After watching fixit so knew how to take back off ,I followed advice about disconnecting battery did this left for few minute.....now have a working kindle again.
完成的
can you direct me to get the instructions for removing the back please as i have the same problem.
thank you
完成的
添加一条评论
I am having the same issue. How do I open Kindle 4 to do this? Can someone please direct me to a good, reliable set of instructions? Thank you.
这个答案有帮助吗?
得分 0
1条评论:
yes i would like the instruction
完成的
添加一条评论
添加你的答案
Denis Keenan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 29
总计 3,210
