跳转到主内容
加入维修社区 - 创建账户
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
Screen is half black
I dropped my phone on its back in an otter box when I picked it up and all but one eighth of the screen was black. I need to know what's wrong and if I can fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 14
添加一条评论
6个答案
已选择的解决方案
Joe, I'd start off by opening the phone, following this guide. Check for any cables having come lose or slightly dislodged. Reseat all of the cables, check for any obvious damage, like broken or missing components. Should all the cables be properly aligned, replace the display. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
How to fix my iphone 5c if half of the screen is black out?
这个答案有帮助吗?
得分 3
添加一条评论
did you find anything? the same has happened to mine
这个答案有帮助吗?
得分 0
1条评论:
You need to replace your screen. iFixit sells great repair kits. The repair isnt too difficult.
完成的
添加一条评论
I haven't dropped my iPhone 6s+ or damaged it but my screens half black? Can someone help
这个答案有帮助吗?
得分 0
1条评论:
It is an old post, but it could be that the cable needs reseating. Follow the iFixit guide for screen assembly replacement to know how to remove the screen, then reconnect it. Of course as per the guide disconnect the battery first.
Otherwise must be tested with a known good screen and the issue remains, have the board repaired. It means one of the backlight circuits is down. Each backlight circuit is composed of diodes, fuses, driver, coil, and caps. Any or all may require replacement.
完成的
添加一条评论
take it to the genius bar at an apple store. they will most likely fix it free of charge but only if one of the wires is dislodged. or, you had a software crash, do a hard reset just incase.
这个答案有帮助吗?
得分 0
添加一条评论
Joe, my iPhone 5 has half of the screen black. I don't have any tools to open it. My phone has water inside of it and suddenly when I woke up half of the screen was black. Water fell in my phone about a month ago and until right now,half of the screen is black . May you please
help me :(?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 23
总计 81,286
