跳转到主内容
Can anyone tell me what is this and what it does?
Hi
I have water damaged macbook air,
I have marked the damaged part on the picture
can anyone tell me what is the name of the chip and what it does
Thank you in advance for your help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Here's am image of the logic board were the chip is located AVO logic board
完成的
添加一条评论
1个答案
已选择的解决方案
Kip, that is reference designator U7930 and it is a Texas Instrument TPS3808G33DBVRG4 in a SOT23-6 package. The description for that is a Programmable-Delay Supervisory Circuit family of microprocessor supervisory circuits monitor system voltages from 0.4V to 5.0V, asserting an open drain RESET signal when the SENSE voltage drops below a preset a logic low. The datasheet for that is available right here. It is a bit hard to come by in a single quantity. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
Thank you Oldturkey and Dan for your help .
I will find and replace it.
完成的
添加一条评论
添加你的答案
Kip 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,044
