Good Grief! I appear to be mentioned in the question above; I am the Chris Fackrell referred to.
I can, and do, repair the TC PSUs that come my way. There are three basic types;
1. Flextronics Mk1
2. Flextronics Mk2
3. Delta.
The DELTA units are very robust and can withstand the furnace temperatures far better than the Flextronics; they overheat and fail in a very predictable way, in that, the secondary capacitors cook and dry out. I remove all 4x of the main failure culprits and replace them with new superior parts, test the PSU on full load and reseal the plastic case holding the electronics.
I give a very easy-to-follow script for the repair of the Flextronics units, on my website listed above.
The DELTA PSUs almost never fail and by not failing they have revealed some very interesting facts about the TC design. (I'm in design, did I mention that?).
There is a basic, known, design flaw in the structural build of the Apple Time Capsule. It overheats - and high temperature kills electronics - FACT.
To obviate this heat problem, the Apple design team built in a very useful cooling fan and when connected and running it works very well. Unfortunately, the design with this fan has three basic faults...
1. The fan has no air inlet hole. It need cool outside air to displace the hot inside air.
2. It is pointing the wrong way. The 'hot spot' inside the TC is the PSU - it generates the power needed to drive the electronics and the hard drive but it is not 100% efficient (no PSU is). The surplus heat is not removed by passing cool air, so the PSU gets hotter and hotter.
3. The fan (as fitted) is not turned on. It WILL come on when a terminal temperature is reached by which time the TC is shutting down.
In Apple's defence, since this problem is known, they have at least on the latest versions turned the fan 'on' and made its speed proportional to an internal temperature sensor.
Too little, too late.
Please note, I will repair a PSU but only if you choose to remove it from the TC. Send me the WHOLE TC and I will repair the PSU AND modify it to run cool and remain so. I call this a 'F&M' (Fix and Modify).
I will NOT fix a PSU and put it back in a flawed TC, only to fail again.
Ahh... point not explained before, when I mentioned the DELTA supply... it highlighted that IT was not the weakest link in the critical chain of components that keep the TC running. The DELTA is tougher than the FLEXTRONICS. This toughness makes something else the weakest link within the TC, that will eventually succumb to excessive heat. That something, so far, has proved to be the main control board, which is beyond my present ability to repair.
Avoid these overheating problems and follow my website in the ways to do it...
Cut a hole. Flip the fan to point the correct way. Turn the fan on.
Sorry this answer was so long. It needed explaining... :-)
Regards,
Chris Fackrell,
YORK, UK.
Hello Kevin,
If the PSU is a Flextronics, probably yes.
If it is a Delta, I will decline; I have not seen the same fault twice, have no schematics for the PSU and hold no spares.
Address per the contacts page on my website.
www.fackrell.me.uk
Regards,
Chris Fackrell
YORK, UK.
3条评论
Have you tried going to a local Apple authorized service center to see if you could order it? Some will do that for you. Otherwise you may need to go to Apple directly.
由 Dan 完成的
The problem is these aren't repaired through Apple's service network, only internally by Apple. When an Apple Authorized Service Provider creates a repair for this they are simply ordering a replacement unit (rather than the individual component) at a discounted cost because it has been rebuilt. Because of that you rarely find the internal components for sale aside from broken "for parts" units. Your best bet for a DIY repair would be to disassemble it, get as much info from the power supply as possible, and shop around with electronics resellers for a similar component, although I suspect it's a somewhat proprietary component.
I wish I had a better answer than that.
由 LikeARabbit 完成的
laurentbouchet, take a look at this writeup for repair. you can send your PSU to places like this for repair. Have you. checked the fuse on the PSU as well as for bad capacitors?
由 oldturkey03 完成的
