跳转到主内容
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
left trigger connector broke off logic board
Made a mistake trying to fix my psp go and made it worse, L trigger no longer works, any way to reattach connector to logic board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thanks everyone for the help I really appreciate it, i am kind of new to all this and i apologize for being uninformative. You all were a great help! Thanks again!
完成的
添加一条评论
2个答案
最有帮助的答案
aaron, the angle of the pictures is a bit distorting. It appears as if your solder pads are still in place. I would resolder the connector. You will need a good soldering iron with a small tip to accomplish that, but not impossible. If you are unsure on how to do it, any decent electronics shop should be able to fix that for you. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
The only way to fix it would be by soldering.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
aaron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 468
