跳转到主内容
Nokia Lumia 920由诺基亚开发并于2012年11月发布,搭载Windows Phone 8操作系统。
56 个问题 查看全部
broken glass but LCD OK
I have broken glass on my lumia 920, but LCD and thouch panel is OK.
What can I replace on my phone? I saw in video guide on this site what LCD+touch+glass is one solid item.
But on ebay I find "Black Front Panel Touch Screen Digitizer" without LCD. It is save my money.
Can I buy this for repair my phone myself, or I can buy full display?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
oldturkey03, thank you, you really helped me.
完成的
Thank you for accepting my answer. Best of luck to you.
完成的
添加一条评论
3个答案
已选择的解决方案
Oleg, yes you can but it is not as easy due to the digitizer being glued to the LCD. You will need a heat source to separate them. Check this video for some great instructions. The complete assembly is available at places like this as well as many others.Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
On Lumia 920 you can change glass without the lcd.
The glass is not glued to the LCD si you can simply remove with hot air ofcorse.
We make this every day in out gsm service.
这个答案有帮助吗?
得分 0
添加一条评论
Chang my phon glass 920
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Oleg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 14,277
