I need to chang the thermostat.
I need instructions on how to change the thermostat for a 1993 Subaru Legacy.
Samantha, try this:"
CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze, and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
1.2L Engine
Disconnect the negative battery cable.
Drain the cooling system to a level below the thermostat housing.
Disconnect the upper coolant hose from the thermostat housing.
Remove the thermostat housing retainer bolts and remove the thermostat housing. If the housing is difficult to remove, tap it lightly with a plastic-faced hammer.
Remove the thermostat and gasket.
Note the placement and direction of the old thermostat, so that the replacement unit is installed in the same way.
Clean all gasket material from both mating surfaces.
To install:
Install the thermostat into the housing using a new gasket. Install the retainer bolts. Tighten the bolts to 7-9 ft. lbs. (9-12 Nm).
Connect the upper radiator hose to the thermostat housing.
Refill the cooling system.
Connect the negative battery cable.
Start the engine and bleed the cooling system.
Check for coolant leaks.
1.6L, 1.8L and 2.7L Engines
Drain the cooling system into a suitable container to a level below the intake manifold.
Disconnect the air intake duct and intake manifold hoses from the thermostat housing.
Loosen the hose clamp, and disconnect the upper radiator hose from the thermostat housing.
Remove the thermostat housing mounting bolts, then remove the housing and thermostat. Note the placement and direction of the thermostat for ease of installation.
To install:
Clean all gasket surfaces completely.
Install the thermostat in the intake manifold.
Using a new gasket, install the thermostat housing and tighten the mounting bolts to 7 ft. lbs. (10 Nm).
Connect the upper radiator hose.
Connect the air intake duct and intake manifold hoses to the thermostat housing.
Refill and bleed the cooling system.
2.2L and 2.5L Engines
See Figures 2, 3, 4, 5, 6
Fig. Fig. 2: Loosen the radiator draincock ...
Fig. Fig. 3: ... and drain the coolant into a suitable container
Fig. Fig. 4: Loosen and remove the thermostat housing retainer bolts
Fig. Fig. 5: Detach the housing to reveal the thermostat and gasket
Fig. Fig. 6: Remove the thermostat and gasket assembly
Click image to see an enlarged view
Fig. Fig. 7: Loosen the bleeder screw on top of the radiator to bleed air from the cooling system
Drain the cooling system into a suitable container.
Remove the thermostat case cover located in the lower portion of the water pump. Remove the thermostat retainer bolts.
Remove the housing, thermostat and the gasket. Note the placement and direction of the thermostat for ease of installation.
To install:
For turbocharged models, install the thermostat with the jiggle valve at the 12 o'clock position.
For non-turbo models, install the thermostat with the jiggle valve facing down.
Install the housing with a new gasket, and tighten the bolts to 52-61 inch lbs. (6-7 Nm).
Fill and bleed the cooling system.
Check the system for coolant leaks.
3.3L Engine
Disconnect the radiator hose from the thermostat housing.
Remove the thermostat housing mounting bolts.
Remove the thermostat housing, thermostat and gasket.
To install:
Install the thermostat and housing with a new gasket. Tighten the mounting bolts to 60 inch lbs. (7 Nm).
Start the vehicle and bleed the system.
Great instructions from here. Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 8,467
