跳转到主内容
The Intellivision is a video game console released by Mattel in 1979.
Can I replace the zener diode?
I was wondering if it was at all possible to tell what diodes are needed to replace the zener diodes that are in the power supply?
I have one in my intellivision that corroded apart and wasn't sure if I should try replacing it, or if I should just buy a parts intellivision and just replace the board alltogether.
*edited to add an image
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
post an image of the location and what it looks like, This may help to properly identify the parts. Use this guide to add images Adding images to an existing answer
完成的
I am sure that replacing any parts is safer than purchasing one for parts. You may just have old parts in that one as well :-)
完成的
添加一条评论
1个答案
最有帮助的答案
skyler, which one do you want to replace
Update
skyler, C9 is actually a non-polarized capacitor 0.1 uF 25V ; CR5 is a IN4001 Diode. If instead of C9 you meant CR9, that is a Zener IN746. Hope this helps, good luck.
Needs Clarification
not exactly sure where you are describing. Are you looking for the components under the heatsink? From your description, it does sound more and more like capacitors. Use a graphics editor to mark the location on your image and repost it, or use my diagram and name the designators.
这个答案有帮助吗?
得分 3
7条评论:
C9 is the zener that is out and cr5 is kinda corroded too
完成的
do they make non-polarized capacitors that look like zener diodes? (or did they I should say)
完成的
Not that I know off, but "C" is definitely capacitor vs "CR" which is a Diode or Silicon Rectifier
完成的
Would you happen to know what the zener was from the codes on it? it has 104z 50v and 8208 or 8z08 it's hard to read
完成的
The 104z could be a most likely 1N4148 switching diodes, but the 50V is confusing. You sure we are not looking at caps? Which part on your image (thanks for posting it) are you looking at?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
skyler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 3,802
