Uncooperative Home Button
My home button does not respond like it once used to. Often, or I should say usually I have to press it more than once to get it to respond or press harder than I'd like.
Can it be replaced by itself and/or will that fix the problem?
1条评论
No this iPhone 3G has never been taken apart nor is the problem that severe that I'd spend $150 on it. It is annoying enough to want to open it to replace let's say a $50 part or less.
The most frustrating part is sometimes the home button works fine but you never know when so sometimes you have to press hard or hard and long and sometimes a normal press will work.
由 velvetpunch 完成的
