跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Uncooperative Home Button
My home button does not respond like it once used to. Often, or I should say usually I have to press it more than once to get it to respond or press harder than I'd like.
Can it be replaced by itself and/or will that fix the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
No this iPhone 3G has never been taken apart nor is the problem that severe that I'd spend $150 on it. It is annoying enough to want to open it to replace let's say a $50 part or less.
The most frustrating part is sometimes the home button works fine but you never know when so sometimes you have to press hard or hard and long and sometimes a normal press will work.
完成的
添加一条评论
4个答案
最有帮助的答案
It should definitely fix the problem.
Here it is, and here's the Guide
这个答案有帮助吗?
得分 1
添加一条评论
Has this iPhone been taken apart before? Due to the way the home button in the 3G[S] model is built, contact between the button and its conductive strip is only achieved through the screen portion being reseated perfectly. It could be that a piece of junk has gotten wedged in between the contact and the button- I would check that before you buy any new parts.
这个答案有帮助吗?
得分 0
添加一条评论
just go settings/general/passcode lock and enable passcode lock. now look
这个答案有帮助吗?
得分 0
添加一条评论
I had this issue before with iPhone 3GS and 4. One very simple solution before you think about replacing any part is the following:
You'll need
- acetone
- cotton ear bud
Procedure: use the ear bud to drop 2 drops of acetone in the home button of your iPhone. Immediately, use the same ear bud to press the button down quickly around 20-30 times.
You' then probably notice the button sensibility appearing again.
This is due to the grease from your own fingers starting to accumulate in the button sensor. The acetone will help to dilute that grease.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
velvetpunch 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 12,379
