跳转到主内容
加入维修社区 - 创建账户
关于第二代 Apple iPad Wi-Fi 版更新机型的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储容量可选。于 2012 年 3 月发布。可通过型号 A1395 和 EMC 2560 识别。它采用了更小的处理器核心和更新的内部结构。维修时需要使用加热和小心撬开。
No Backlight after digitizer replacement Help!
Hi, I just replaced the digitizer on a friend's ipad, and being my first time I disconnected the screen with a metal screwdriver (big mistake). The iPad boots and I can see the Apple logo perfectly, but then, when it gets to the lockscreen it turns pretty dark, I can only see something with a flashlight. Any idea as of what to do now?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I guess I should be able tu just jump the shorted part.
完成的
添加一条评论
4个答案
最有帮助的答案
The best thing to try first is a hard restore which if the digi is still off touch both probes with something metal inside under the lcd by where the home button is. If there was any damage to the digitizer flaps (FPC's) than that is a bigger problem and will require a soldering repair. Was the device powered off when you took the lcd and digi off?
Update this to let me know what happened Please!
这个答案有帮助吗?
得分 1
4条评论:
I already did a reset, still no luck. The iPad was off when I removed the digi and the LCD, but I think my mistake was to remove the LCD latch with a screwdriver. Any thoughts? I forgot to say that the figi is working well, the only problem is the backlight
完成的
Okay try disconnecting the battery from the motherboard. If this doesn't work it means you have to replace a coil and the black light chip. That involves some very complicated soldering.
完成的
That is sad, removing the battery didn't worked either. Which chip and which coil would I need? Do you have the schematics?
完成的
And is there any way to just jump the shorted parts?
完成的
添加一条评论
Your backlight filter isn't fully blown but has too high of a resistance. That's why you can see the apple logo at first but dies during the iOS screen. You can test with a meter (resistance value of .2-.3 ohms). If its out of spec, you could jumper it but its easier and overall safer to replace. I have replaced lots of these. You can email me if you need service.
这个答案有帮助吗?
得分 0
6条评论:
I would surely like to get help from you, but I guess it will be quiet hard, since I am in Mexico. So I guess I will either have to look for someone near me or do it myself. So I should only replace the filter? Or also the chip?
完成的
Well you need to test before you replace. The filter is not directional. It doesn't make a difference in the reading which ever side you touch with your meters leads. It should always be the same reading .2-.3 ohms.
The backlight ic chip is a 2 lead black chip marked with a JH. It is directional. The positive lead has to be on the chip lead closer to the the JH label. A resistance check should reveal 160-190 ohms.
The backlight coil is labeled 4r7.... It's square and silver. Should be non directional with a resistance value of .2-.3 ohms. I suspect it's fine as your backlight does fire up.
完成的
And how do I remove the shielding over the logic board? Hehe, I didn't think of that before.
完成的
Hi yaya, I am getting 469 ohms across the backlight ic chip, is this bad?
完成的
Im having the same problem but what is the most strange on it is that i turn it of plug the cable and show me charging with normal light but then starts and apple logo is again really dark. I tried to remove the battery and full reset but didnt help. Any other ideas before replacing the filter? Thanks in advance for any help
完成的
显示更多的1条评论
添加一条评论
just disconnect the battery and leave it for about 10 seconds and connect again....i did it to mine when replaced the touch screen and worked...!!!
这个答案有帮助吗?
得分 0
1条评论:
OP mentioned that he already tried this.
完成的
添加一条评论
http://www.instructables.com/id/iPad-2-L... This easy fix worked for me.
这个答案有帮助吗?
得分 -2
添加一条评论
添加你的答案
Rodrigo Alatorre 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 8,215
