跳转到主内容
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
222 个问题 查看全部
battery physical size (in relation with LG G2)
Hi,
may you confirm the physical size of the Nexus 5 is identical to this one of the LG G2?
Is it technically possible to buy the silicon battery of the G2 (3000mah) and install it in the N5 (same connector, same voltage aso)?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
I'm also looking for an answer to this as I'm looking to purchase this-->http://www.smavtronics.com/3000mah-bl-t7...
完成的
添加一条评论
3个答案
最有帮助的答案
I4U, no you can not. The batteriy are different sizes
LG G2 BL-T7 size 55mm wide X 67mm long
Nexus 5 BL-T9 size 57mm wideX 60mm long
and the battery cable is on a different position.
这个答案有帮助吗?
得分 3
添加一条评论
I don't know about the physical size but looking at the LG G2 user teardown and the Nexus 5 featured teardown:
  • Nexus 5 battery reference is BL-T9
  • LG G2 battery reference is BL-T7
  • mAh's are different
  • Finally the battery connectors looks not at the same places
I think we can conclude that you can't install a G2 battery on a Nexus 5, sorry. However, there is Nexus 5 batteries available on internet. Look for "LG BL-T9" on google and don't miss the Nexus 5 Battery Replacement guide on iFixit.
Nexus 5图片
指南
Nexus 5 Teardown
难度:
中等
LG G2图片
指南
LG G2 Teardown
难度:
中等
30 minutes - 1 hour
Nexus 5 电池图片
指南
Nexus 5 电池更换
难度:
中等
20 - 40 minutes
这个答案有帮助吗?
得分 1
添加一条评论
the size seems to be different
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
I4U 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 6,257
