My iPod wont charge or be read by a computer
*it wont charge
*it cant be read by a computer
Ashten, you did not tell us what you've tried thus far to fix it. First you might want to try a hard reset, check on here for information on that. Start off by using an AC adapter to try to charge it. Make sure that you have a known working cable. Check your dock connector for any debris, broken or bend pins. Clean it with isopropyl alcohol. If that does not work, you could try to disassemble your iPod, check the battery. Replace it since it must be coming to the end of it's lifetime. Hope this helps, good luck.
这个答案有帮助吗?
Since you're not being very specific, what have you tried? Hard reset might work, same with trying different charging cables, but if the iPod has been off or dead for a number of years it's likely that the battery might have gone flat. Since Apple no longer repairs these devices since they're obsolete, there's a good chance you might have to disassemble it yourself and have a look. If this is the case, you will need a new battery which will probably be hard to find considering the age of this device. It's an old iPod so it's common that the battery would be dead. This is why you should charge it to 50% and power it down when you're going to store it for a long period of time. Either way, I would replace the battery because like oldturkey said, it's coming to the end of it's lifetime.
这个答案有帮助吗?
To hard reset, hold the power button and home button at the same time until you see an Apple Logo.
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 9
总计 161
1条评论
What have you tried to fix it?
由 oldturkey03 完成的
