跳转到主内容
Repair information for the PowerBook 180, released from Apple in 1992. Model number: M4440.
Blown Capacitor at point D15 on Logic Board
Hey guys!
So I acquired a powerbook 180 from work. Unfortunately, it didn't work when I plugged it in. I opened it up, took it apart, and found a bulging capacitor. It's square, has the letters KM on it, and is set at pins labeled "D15" on the logic board near the charging port. It gets very hot when plugged in.
Any idea how I would go about fixing this or acquiring parts?
Pictures at this link:
http://imgur.com/a/Y6xjv
You can see there is electrolyte leaking from the part.
Thanks!
-A
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
the letter D makes it a Diode, not a capacitor. Now we just have to find the right one:-)
完成的
添加一条评论
2个答案
已选择的解决方案
afischer15, just checked your images again. The "KM" you referred to is actually a "KW" That marking and the D15 identify your component as a DDZ13B SURFACE MOUNT PRECISION ZENER DIODE. The part is available at places like this. The datasheet containing all the specs for the diode is available right here. Hope this helps, good luck
这个答案有帮助吗?
得分 3
5条评论:
Thank you for accepting my answer
完成的
Hate to bump this old thread, but I wanted to let you know that I was able to use my (somewhat lacking) soldering skills and get the computer to boot successfully. You rock!
完成的
You know what? that is actually really great of you, to come back here to let us know you got it done. That is truly great fixin' Thanks for letting us know.
完成的
Thanks for this info. I replaced D15 with DDZ13B SURFACE MOUNT PRECISION ZENER DIODE from Mouser but it seems too small. I was able to get it to power on now but the PB180 powers off after a high current draw (hard drive booting up). Is this Zener diode suitable for location D15?
完成的
@mikematkovic I just re-verified and yes, that is the right one for D15
完成的
添加一条评论
Hello, afischer15!
Please let me know, you just replaced the diode DDZ13B and the computer turned on successfully?
这个答案有帮助吗?
得分 0
1条评论:
Wow, this is old!
Yes - I was able to get the computer to boot after replacing the diode. It is a bit finicky, sometimes the screen flickers, and the computer shuts itself down when a floppy is inserted, but it boots to the login screen just fine. I haven't had time to try to figure out the password, sadly. I do have the number of the former owner... I should call him up.
完成的
添加一条评论
添加你的答案
afischer15 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,169
