跳转到主内容
Eighth generation of the Mazda Protege.
20 个问题 查看全部
1998 Mazda Protege Starter
Where is the starter and is there any helpful free guides??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Brian, the starter is located between transmission and engine down intake manifold. Look for number 17 in the diagram
STARTER REMOVAL/INSTALLATION
Warning
• When the battery cables are connected, touching the vehicle body with starter terminal B will generate sparks. This can cause personal injury, fire, and damage to the electrical components. Always disconnect the battery before performing the following operation.
1. Disconnect the negative battery cable.
2. Remove the battery.
3. Remove the intake manifold bracket.
4. Remove in the order indicated in the table.
5. Install in the reverse order of removal.
这个答案有帮助吗?
得分 3
3条评论:
Which engine is this for?
完成的
@mememachine what are you looking for?
完成的
Where does the plastic cap go onto? And the other part that's connected to the neg battery wire?
完成的
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 15
过去 30 天: 45
总计 22,209
