跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Screwing the MacBook Core 2 Duo back together
Does anyone have a step-by-step guide to screw the MacBook back together, particularly, where the screws should be placed? Any advice will be much appreciated! Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Ehh, just screw it. :P
完成的
添加一条评论
2个答案
已选择的解决方案
Here's one of the more complete guides. Most of the screws are circled with listing of what length they are. Where to start is dependent on far far you tore it down. What did you do?
MacBook Core Duo Display Replacement
这个答案有帮助吗?
得分 2
5条评论:
Someone disassembled it to replace the hard drive and its flex cable. I have 25 screws and don't know how to replace them. Thanks for your help!
完成的
The MacBook is easy - the important part is to stay calm, an iBook would be worse to reassemble. look at the guide and sort the screws - then put it in the right place
完成的
Any idea of where to find the guide for the placement of the screws for the external frame? I have given up with the internal frame. I just need to have it somewhat assembled so I can send it away to Apple depot to fix it. I think the logic board is broken.
完成的
The guide I gave you starts with the external screws
完成的
添加一条评论
depends on the MacBook you have
here are the guides for the MacBooks
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the reply. It's a Core 2 Duo, but I still don't see a guide for the exact screw placement for reassembly.
完成的
you need to follow guide from the end to the begining...
完成的
添加一条评论
添加你的答案
Jon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,378
