跳转到主内容
The Skullcandy Skullcrushers Subwoofer Stereo Headphones in Black Pinstripe will literally pump the music right into your head! These power packing headphones feature an adjustable in-line bass amplifier and speakers with industry first built-in vibrating subwoofers. You can adjust the amount of bass effect with the in-line control wheel.
11 个问题 查看全部
问题已关闭
Bass does not work and not works periodically. battery holder
I had my headphones for a year. All of a sudden, the bass goes on and off. I opened the battery compartment and sometimes when i listen and press the battery towards the minus, the bass comes back on. Is there a way to adjust the metal to have the bass on? And my battery works too.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Patrick Chan,your negative post is a simple spring, and you could just pull it to elongated it. Do make sure that this is the problem, check the ground connection on your board as well as the solder connection to the wire.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 3,248
