跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
How to replace infrared sensor and power LED light
I recently was trying to replace my hard drive and severed the LED light from the infrared sensor. I am having a heck of a time trying to replace this component. Is there any tricks to removing the LED power light and IR sensor?
Thanks,
William
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hey
I dameged this part when trying to fix hard drive and its flat cable cut down, but right now my laptop doesn't turn on.......what do you recommend...?
完成的
添加一条评论
2个答案
最有帮助的答案
You know, I was asked this very question a while ago and endeavored to replace that part. With a small stack of junk cases, I did not manage to successfully replace any of them. They are just situated in the case with plastic reinforcement to not be removed! Replacement would involve re-melting small plastic pieces together, which isn't feasible.
Your best bet is to replace the lower case.
Sorry! At least you know it's not just you.
这个答案有帮助吗?
得分 2
1条评论:
At least the remote sensor is functioning OK without the LED. I am going to leave it AS-IS until I damage my lower case. I appreciate your insight.
完成的
添加一条评论
well, that happens when you do things you are not qualified to. But how will you learn but by trying? Keep up the good work, don't get discouraged - in the end you WILL win!
这个答案有帮助吗?
得分 -1
1条评论:
That's not exactly an answer. And not exactly too encouraging either
完成的
添加一条评论
添加你的答案
nrgflow 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 2,837
