跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 个问题 查看全部
问题已关闭
did the hair-dryer 'reflow' - and it did not fix my '360.
I've installed the iFixIt "Xbox 360 Red Ring of Death Fix Kit", did the hair-dryer 'reflow' - and it did not fix my '360.
I suspect the heat from the hair dryer was insufficient; of course, there could also be a different, unrelated problem with the motherboard that the iFixit kit does not address at all.
Anyway, I am now interested in trying your approach; could you please clarify the following:
1. Your method would 're-flow' only the GPU, right?
2. Is overheating the GPU done with its heatsink on?
3. It sounds like the 'GPU overheating' is done by turning on the system while it's disassembled, right?
--- 3.1 If so, what exactly should remain connected to the motherboard?
4. Is there a more detailed description of the 'GPU overheating' method anywhere?
THANKS!!
CDP
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
AV Phile, you can not do a reflow with a hair dryer. For the why not, check on here. I personally would recommend that you use this Reflowing Xbox 360 Motherboard. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 2,302
