The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
419 个问题 查看全部
did the hair-dryer 'reflow' - and it did not fix my '360.
I've installed the iFixIt "Xbox 360 Red Ring of Death Fix Kit", did the hair-dryer 'reflow' - and it did not fix my '360.
I suspect the heat from the hair dryer was insufficient; of course, there could also be a different, unrelated problem with the motherboard that the iFixit kit does not address at all.
Anyway, I am now interested in trying your approach; could you please clarify the following:
1. Your method would 're-flow' only the GPU, right?
2. Is overheating the GPU done with its heatsink on?
3. It sounds like the 'GPU overheating' is done by turning on the system while it's disassembled, right?
--- 3.1 If so, what exactly should remain connected to the motherboard?
4. Is there a more detailed description of the 'GPU overheating' method anywhere?
THANKS!!
CDP
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
1个答案
已选择的解决方案
AV Phile, you can not do a reflow with a hair dryer. For the why not, check on here. I personally would recommend that you use this Reflowing Xbox 360 Motherboard. Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 1
添加一条评论
添加你的答案
AV Phile 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 25
总计 1,503
