跳转到主内容
加入维修社区 - 创建账户
HP Pavilion 700 系列是一款台式机系列,配备 512 KB 已安装内存和 512 MB 内存 (RAM)。
Computer will not start
HP Pavilion 700. When I switch on the fan
runs for about 30 secs nothing appears on
the monitor, then switches off.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Hi,
a normal procedure is to unplug everything until you only have:
power supply, motherboard, a single RAM module, processor with fan, a graphic card and a keyboard. In this minimum configuration the PC has to start....graphics bios....bios....no boot device found.
If that configuration works, bit by bit plug everything back in until the failure shows up again and you have your "troublemaker".
If the configuration does not work, take another graphic card....try if it works. Take another RAM Module.........try if it works. Take another keyboard......try if it works. Take another power supply..............try if it works. If it still doesn't works its the motherboard or the processor.
这个答案有帮助吗?
得分 5
1条评论:
+ Ralph
由完成的 分享
添加一条评论
you could try changing the motherboard battery, and also look for a small 3 pin "jumper" on the M/B close to the battery, which might say "reset", maybe not, but if moved to the other two pins, (using the center one in both instances) then move it back to it's original location, after a few minutes, might get your bios re-written, just incase there's a problem with that software stored there, I've recovered many dead PC's with just that one little trick. good luck
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
I just spent ALOT of time resolving this very issue with an HP Pavilion A1010Y.
It turned out to be the following:
The Heatsink frame had cracked and 2 of the 4 screws that hold the Heatsink to the CPU for cooling, weren't doing their job.
Also, NO Thermal Paste remained.
I replaced the Heatsink, Fan and Thermal Paste and Now it works fine.
Sounds like yours is overheating, just like the one I just fixed.
Good Luck
Phil
这个答案有帮助吗?
得分 0
添加一条评论
plese replace your smps .............ok
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Dunne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 5,804
