跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
PSU Test Fail Confirmation
I have an a1224 emc 2210 that won't fire when you hit the switch. I have #1 led lit up but nothing happens when you press the button. I checked continuity on the power button- definitely working. I then went to the power supply and got the following readings from each pin-
1-0v
2-0v
3-0v
4-0v
5-1.16v
6-0v
7-0v
8-0v
9-3.41v
10-0v
I'll assume it was in the standby mode..but either way these numbers seem off compared to what I should be seeing..
Any confirmation here would be great- I'm new so take it easy, just want to see if it looks like psu is bad..
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Jay Cov, see if this guide will help you. Sure looks like your PSU is off on the voltages.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jay Cov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 134
