跳转到主内容
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
Graphics chip repair with heat
Hi, I was wondering how can I repair iBook's g3 famous graphic issue. So, does putting logic board in to oven for awhile will do the job? I was thinking about 300 celsius.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
watrobkasmaczna, the idea about a reflow is that it reheats the solder. The theory is that fractures form inside the solder points on boards, which causes instability. By reflowing the solder, you could get rid of the fractures, and sometimes you can bring apparently dead parts back to life. But, there is a bit more to it than just throwing it in an oven :-) Check on here on here for more information about reflowing. This idea or even this one might be a better way of doing it, unless you have a reflow station. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
watrobkasmaczna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 190
